15" wheels for 96 Camry?
As I mentioned elsewhere, I just inherited a 96 Camry wagon. I was surprised to see that it has 14" wheels as my 94 Accord has 15" wheels.
I just put four new tires on the Accord before it died. What I'd like to do is pull those tires off the Accord and stick them onto the Camry. So before I head off to the junk yard, are there some 15" Toyota wheels that will fit my car? |
I sorta have the reverse problem but I don't want to let go of my 15 inch wheels as my 14 inch wheel situation would only be temporary. I have a 2004 Camry with 15 inch wheels and need to know if its possible to run 14 inch wheels on this car and have proper clearance. I wonder if the 96 Camry and 2004 Camry have the same bolt pattern? If so I may be interested in your 14 inch wheels as cheap as possible as Im sure you want those 15s as cheap as possible. In your situation I think you are better suited to move from 14 to 15 and I might have more difficulty moving from 15 to 14. Im in Kentucky if you are interested in getting rid of your 14s and we can determine if they will work on my car.
What part of Kentucky?
Bowling Green 42102 zip
