Go Back  Camry Forums - Toyota Camry Forum > Your Ride > Suspension, Brakes, Tires & Wheels
Reload this Page >
18 SXE. What PSI are you guys running on those 19x 40 Series tires?
Sponsored by:
Sponsored by:
Old 04-02-2019, 08:13 AM
Default 18 SXE. What PSI are you guys running on those 19x 40 Series tires?
We just got this fella and itís my first time relenting to having those high $$ / performance tires and rims. The door post says 32 and tire says 51 PSI. Iíve always run my tires near or at max tire stamping but these dudes are a fit stiff at 50. So what do you folks usually keep yours aired up to?
Old 04-02-2019, 12:13 PM
Assume the previous tires had a max rating around 44 PSI. Just because the new tires are 51 doesn't mean one should use this. At a MAX tire load at a MAX pressure.
Suggest you start out at door post PSI and work up to a max of around 41 PSI (cold).
Tirerack.com has a lot of articles on setting tire pressure.
If you want lots of detailed info read the article at the link below:
http://www.toyotires.com/media/2125/...s_20170203.pdf
camryclay1999
08-25-2017 12:52 PM
CaMRy4LiFE
08-11-2010 08:34 PM
bighit699
08-26-2008 05:50 PM
Quick Reply: 18 SXE. What PSI are you guys running on those 19x 40 Series tires?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
