1989 4WD Rear Struts
I know they are hard to find but has anyone had success in replacing the rear struts/shocks on the 89-90 Camry Alltrac with 4WD? I think Toyota part # is: 485303-2150, 485403-2150. A cross reference to another brand that fits would be most appreciated.
You sure these are the right P/N's.
Check at parts.olathetoyota.com which should have the part listings. |
Yes I have checked that website and several others using the VIN numbers and I'm 90% sure those are correct. I can't find them under Monroe or KYB cross reference nor NOS listings. Maybe there is a similar fit that has worked for a different model vehicle?
48530-32150, 48540-32150. Toyota discontinued them. Rear struts are apparently shorter then the 2WD car.
An Ebay UK has a seller but they want over $300 US for each strut. Suggest a search at Toyotanation.com. Someone states they were able to get Tein ST185 Super Street coilovers to work on the rear of the Camry Alltrac. ST185 is the Celica Alltrac. https://www.toyotanation.com/forum/1...rac-camry.html |
