2002 Camry - 2003 Lexus Wheel Fitment
I have a 2002 Camry with the 15 inch steel wheels and worn out tires. I found a set of 2003 Lexus GS300 sport wheels with almost new tires an hour or so from my house. The tires are 225/55/R16. I did the tire/rim calculator and see that the fit is close. My biggest fear is that the back tires will rub- There isn't much clearance there. I have no way of test fitting them before I buy them. Is there anybody here that can tell me if these wheels will fit or not before I spend hundreds of dollars and 4 hrs of my time? Thank you in advance!
Try asking at Toyotanation.com which covers both Camry and Lexus.
The biggest change appears to be decreased strut/rim clearance due to rim offset differences. This may require a wheel spacer. See link below: Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit |
Thank you for your advice! :)
