struts/shocks 2000 camry
Old 04-14-2007, 02:29 PM
james007's Avatar
Default struts/shocks 2000 camry
What does the 2000 camry have struts/shocks? Approx. how many miles did they last, and how much to replace?
Thanks
Old 04-14-2007, 07:33 PM
OnE_To_HatE's Avatar
Default RE: struts/shocks 2000 camry
i changed mine @ 80K w/KYB GR-2. A little below 400 shipped on eBAY for all 4. But they're suppose to last up to 100K.
Old 04-15-2007, 02:05 PM
trd_camry's Avatar
in reality stock shocks are probably worn out by 75k miles , but its such a gradual reduction in performance that you really dont notice , until you put the new tokico,bilstein or kyb's in .
i think they are all about the same price . i just put on tokico's because they are slightly more forgiving on rough roads , but still have similar performance as the trd bilsteins that were on my 99 .
Old 04-15-2007, 06:13 PM
james007's Avatar
How easy wwere they to replace?
Old 04-16-2007, 11:45 AM
trd_camry's Avatar
ORIGINAL: james007
the fronts are very easy , you will need a spring compressor or maybe take it to shop and have them put the springs on shocks.
the rear is a complete pita . you have to take every piece of trim out of the back to get to the upper mounting bolts . it took me longer removing the trim (breaking several little cheap clips in the process)
than the springs ., but all in all its pretty straight forward . pick up a haynes repair manual from an auto store it may come in handy .
Old 01-02-2012, 03:41 PM
toyota2000's Avatar
Default i feel the car from the driver side low lettle abit from the passnger side from front
I have 2000 toyota camry 4 cyl
its 76,000 miles its excellant
conditions recently
i feel the driver side from the front wheel low rather than the passnger
i went to check it if it need alighiment but then result "alighmnet is complince with manufacturing company"excellent
is this from the shocks or springs??
Garvinsam
10-22-2014 03:49 PM
kai920
03-23-2011 10:50 PM
madquake
05-28-2008 07:24 PM
henry.hendawg
05-05-2008 04:12 PM
bobmugen
09-06-2007 12:47 AM
Quick Reply: struts/shocks 2000 camry
