2007 EOM wheels on a 2016 Camry?
I have a set of OEM steel wheels with winter tires for my 2007 Camry LE; will they fit my 2016 Camry LE? The EOM part numbers for each year’s steel wheel is different but they both appear to be 16X6.5 with a +45mm offset, so I assume they will fit. Can anyone confirm this or will I be the first?
Also, does anyone know if the TPSM reset in the glovebox of the 2017 will allow for the swapping between winter and summer sets, or will they need to be programmed? As always, any suggestions are welcomed and I thank you all in advance. Ian |
45 mm was used offset. The rest can be read of tire or measured then compared.
Where people run into issues with rims other then offset and bolt pattern (same). Is trying to mount too large of tire. Use a tape measure to check the tire mounted RIM clearance on a front/rear tire. Then mount the rim front/rear and recheck. |
