2010 Camry LE w/16" steel rims
Will 17" SE factory rims work on my Camry LE? Does year of rims matter?Will this effect the speedometer accuracy? Are all Camry rims interchnagable between the XLE and SE? I want to get alooys for my car and didn't kknow if it would be a mistake or not. I just do not like the hub caps...
LE, SE and XLE are package options for the same chassis.
17 inch rims will bolt up. Toyota has used the same bolt pattern on Camry for 20 years. But other models of Toyota cars such as Corolla may not bolt up having a different bolt pattern. Suggest reviewing recommended tire and rim sizes at the TireRack.com site for this model and year. A different tire size will cause a slight change in MPH reading. There are sites on the internet that will calculate the change based on new and old tire sizes. |
