99 Camry too low
I just bought a 99 camry XLE a few months ago. I love the car but the area i live in has a lot of speedbumps and the bottom of my car scrapes everytime I go over a bump. Since i have no way of avoiding the bumps, I want to raise the car a few inches. Any advice?
RE: 99 Camry too low
Might be able to get away with harder springs...
There are also "helper" springs that you can sort of clamp on to your existing springs that stiffen them up.... |
is the car on non-oem suspension? if its non-oem.. then go grab some oem camry springs. I have a set if you need some.
yeah was the car lowered? i know the gen4 is pretty low because of the two large and low chasis railsthat run under the car, but typically its fine.
you may want to look into changing the struts if those are too old/worn. |
ORIGINAL: OnE_To_HatE is the car on non-oem suspension? if its non-oem.. then go grab some oem camry springs. I have a set if you need some. |
