ABS kicks on for no reason. 99 4cyl LE
Occasionally, my ABS kicks on for no reason. Usually when coming to a stop, it will kick on just before the car stops. Odd...
My plan is: Pull off all 4 wheels, check the abs rings, make sure sensors are clean. Check all connections. I tried to pull codes with a jumper wire using instructions I found, and couldn't get any codes, the light just flashed fast. Any suggestions? |
It sounds like you have a pretty good plan in place. The sensors seem to be messed up.
Getting the code read would be my only suggestion as it might narrow down the hunt. |
Ditto on sensor issues.
Try cleaning them and the ABS signal rotor (tone ring). Check the gap between the ring and sensor and make sure one is not larger/smaller then the others. |
