Abs, traction control, brake lights on after rear hub assembly replacement
Just replaced both rear wheel bearing hub assembly in my 2012 V6 SE. Now the abs, traction control and brake lights won't go off. Checked and double checked the connectors to ensure they were seated properly. Even tried disconnecting the battery in an attempt to reset the system. Any input, ideas would be greatly appreciated.
Is it possible the hub units were installed on the wrong sides of the car as in now rotating backwards?
Same issue. Did anyone ever figure this out? Thanks
I am having the same issue. Same car same engine. Replaced right rear bearing hub assembly and now ABS, Trac and brake lights are on. Tried resetting a light but no dice
Originally Posted by Terry Nicholson
(Post 100279)
