Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   Suspension, Brakes, Tires & Wheels (https://www.camryforums.com/forum/suspension-brakes-tires-wheels-16/)
-   -   Brakes (https://www.camryforums.com/forum/suspension-brakes-tires-wheels-16/brakes-49439/)
Masterwood55 04-27-2014 09:08 PM
Brakes
Just did my front brakes on my 89 Camry for the first time. I've done many other brake jobs on other cars but never this one. After replacing it sounds like there is something dragging or scraping against rotor did I miss something or do something wrong?
toyomoho 04-27-2014 11:00 PM
If the sheet metal backing plate was bent, it can scrape against the rotor and make noise.
Patonium 04-27-2014 11:33 PM
I have also had the backing plate contact the rotor before and it could be that. Also check all those little metal shims that the pads sit in. Sometimes they can contact the rotor as well. I suggest you pop off the wheel and spin the rotor to nail down where the actual contact is being made.
Masterwood55 04-28-2014 08:05 AM
Ok will check thanks for the input. Will let you know what I find
