can't decide on a lowering spring help.....
Hi, have a 2001 toyota camry 01 and dont want a slammed look. I am looking at the TRD or Eibach lower springs to clean up the fender gap a little and improve performance. This is an everyday driver for my wife. Does anyone have any advice which is better and where to buy either? I also don't want a raked look so any pics or links would be appreciated. Also, what shocks should I match up if I decide to replace? New to Toyota and don't know the hype. Not even sure if I need to replace shocks if I can find a spring that doesnt lower much. THanks
RE: can't decide on a lowering spring help.....
what is the advertised drop on those two springs?
EIBACH
The Eibachs are 1.2-1.4 inch all around (I can't seem to get a consistent answer on any search)
The TRD are 1.25 front and rear. Thanks for any more input. |
i think trd is made by Eibach..so both should be same...if u want alittle drop u can try Tein H-tech its 0.9 front and 0.1 rear or S-tech 1.5 front .6 back
If you only want springs... Eibach prokit. 1.2" in the front, and 1.5" in the rear. Pretty cheap too... $250 at horsepowerfreaks.com I'm thinkin about buyin them.
-Jason |
