Eibach Springs on 97 V-6
Hey
I'm thinking of putting Eibach's on my 97 V-6 to get a little more performance for autocross, has anyone tried these before?Also, I haven't had any luck finding an anti-roll bar for the front, does anyone know of an aftermarket brand? |
RE: Eibach Springs on 97 V-6
You really want to make a significant difference...go full coil-over setup.
Springs will work fine - those eibach are popular and its basically what TRD uses. You will loose some clearance, so always keep that in mind. Sway bars...a company called Whiteline makes them, but pretty darn pricy. I have the rearbar. Along with the springs, put in some stiffer/high performance shocks - none really come to mind right now. OEM and OEM replacement shocks are soft and will wear/blow out much faster when used in combination with lowering springs. Hope this helps. |
Yeah, thanks for the help. I'd love to put coilovers on, but I am pretty limited by price. Also, thanks for the advice on the sway bars, i'll have to look them up.
