Part ID needed - stabilizer bar related 1998
Hey all... I just tried to replace the stabilizer bar bushings on my GFs 98 Camry and managed to snap off one of the bolts holding the bushing bracket. It' s so corroded that I couldn't even drill it out and use an easy out. So, thinking I need to replace the piece the stabilizer bar bushing bracket mounts to? If anyone could identify what that piece is called, I'd appreciate it if you could let me know so I can source a replacement. Any other suggestions also most welcome.
Thanks in advance!! |
This may be reasonable common on Camry's with rust issues.
Suggest you review past posts at the Toyotanation website, Camry, Lexus, Avalon sections (used the same frame). If you don't find anything on post your question to the site. |
