question,about camry gen4
i'm from indo,n i new in this forum..i have some question bout this car..sorry if my english bad,hope u all can help solve my prpblem here..
1.if i drop rear spring,1,8-2" are the abs sistem use normally?bcause my friend say,if i do that can broke the abs sistem. 2.i want put my 19' rims in this car,but rear 19x10" n tyres 245/35 offset 20..can i?without wide body.. 3.what spring better i chose to get comfort with 19"?the brand i choose.. |
RE: question,about camry gen4
okay only thing about suspension to be noted is that the abs sensors (speed sensors) must be disconnected from the struts prior to strut removal as they are prone to break and it isnt an cheap part to replace. although it is easily replaced.
im not so sure u can simply mount those massive rims on without body modifications. if ur just doing springs and you want to keep comfort, go with tein h. techs. otherwise you can go tein s techs or eibach pro springs. |
