Quick Tire Question
I'm thinking of replacing my stock 205-65-R15 tires with Falken 225-45-R17's. I'd have almost the same rolling diameter as with the stock tire, but I was wondering if fitting that wide of a tire would cause any clearance problems with my '97 camry. My plan was to use 215's, but Falken doesn't make the Azenis in a size that would let me keep the original diameter. Any suggestions, recommendations, advice? Thanks
RE: Quick Tire Question
You will need a 10 mm spacer
what made you decided to replace it?for that's fine . . .
