Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   Suspension, Brakes, Tires & Wheels (https://www.camryforums.com/forum/suspension-brakes-tires-wheels-16/)
-   -   Rear drums (https://www.camryforums.com/forum/suspension-brakes-tires-wheels-16/rear-drums-38082/)
heyitsdatguy 02-24-2011 02:37 PM
Rear drums
Has anyone ever tried to switch out the rear drums to brake disc? If so which model can/will fit? I believe the Lexus ES share the same chassis so maybe those may fit?
Feedback? Anyone?
- Dawly
toyomoho 02-24-2011 11:24 PM
It has been done and is reasonable common.
Review past posts at the site below where it has been discussed, might even find posts with photos.
www.toyotanation.com
Conversions have been non-abs cars.
The Lexus ES and Avalon shared the same chassis. But Lexus may have moved away in latter years, don't know. Recall rear disks may have been an option on Camry and standard on cars with the V6 option. Its a bolt on job but you need all the parts.
What year of Camry?
heyitsdatguy 02-27-2011 01:10 PM
I have a '93. I can do the work. I just needed the info on which car can fit it with no modifications.
Replacing pads instead of shoes is much easier.
- Dawly
toyomoho 02-27-2011 05:49 PM
The rear disk setup does have shoes for the emergency brake.
Check 92-96
heyitsdatguy 02-28-2011 02:25 PM
..... Well .... it'll still be alittle easier.. Braking will be better at least right?
