Replaced tires on 07 Camry SE and tire sensor not working
Just had my 4 tires replaced on my 2007 Camry SE. They had the original tires on them.
The tire pressure sensor refuses to turn off now.
I have followed the instructions in the user manual to reset the sensor, checked and made sure the tire pressure is correct. Nothing seems to work.
Anyone else have this issue?
Is the light steady or flashing?
Have you checked the tire pressure including spare? Make sure the tires all have the same pressure (including spare) before you reset.
If flashing there is problem with tire pressure monitoring system.
bthornic
04-27-2014 11:16 PM
appleredcamry
06-14-2009 07:06 AM
pdiddy
05-09-2009 04:56 PM
2007, 2009, 2010, camry, deactivate, disable, light, pressure, replacement, sensor, sensors, tire, toyota, transmitter, xle
