rim size advice
i know this question might be starting to get annoying....
i just got an 07' LE....can i fit 18's with tires, without effecting the speedo or mpg at all? should i go with 17's instead? i am the f.n.g.... |
RE: rim size advice
if you don't want to buy one that's gonna affect your speedometer- then stick with the size the car came with- or as you increase the size ov the rim.. get a tire with a lower profile to make up for the used space.
RE: rim size advice
yeah, thats what i thought....thanks buddy
RE: rim size advice
Find a website with at tire calculator. I believe for the Camry's if you want as close to exact on the speedometer with an 18" wheel and tires...the tiresize is 225/45.
RE: rim size advice
RE: rim size advice
I too have a 2007 Camry LE (completely stock) and just put 18s on this week. I installed a set of 18x8 Privat Zentralle wheels with +40mm offset. A set of Goodyear Eagle ResponsEdge tires 245/45-18 were fitted on those. The total package fits with absolutely no problems at all. The stock tires were the 16x6.5 (w/+45mm offset) steel wheels, plastic hubcaps and OEM TPMS with the OEM 215/60-16 tires. The OEM TPMS sensors from the steel wheels fit the Zentralle wheels with no problems. I will try to post some pictures or can probably email them to you if you like. The effect is night and day. Everything fits inside the fenders and ride quality is great. Hope this helps you.
RE: rim size advice
Hows it going Camry V6, I also have a 07 LE (but 4cyl), was wondering if i could see ur wheels/tires if u have pics.. thanx in advance.
