Rims
Hey all, I am new to the forum and I just have a few questions.
I already tried to search around the site, but was wondering if you can put 20 inch rims on a 2000 Camry? If so, what profile do the tires have to be? Thanks |
Depends...
You'll likely not be able to get 20" rims with tires that're the same diameter as your OEM ones, but some things to consider... Did you lower/raise your Camry? Will you care if your tires rub the inside of the wheel well when the steering wheel's max'd out? You can also get spacers or longer hub bolts if you don't mind your wheels sticking out the sides of the car a bit. I've got 17s but would get 18s or 19s if I could do it over. I'd recommend going to a wheel place near you and telling them what you want. They'll go through the whole process with you Then you can decide whether to buy them there or leave and get them online, or whatever. |
