Sienna wheels on Camry?
Hi Guys, I'm new here and I just got a 2013 Camry. I'm just wondering if OEM sienna or highlander OE rims will have any fitment problem with my 2013 camry?
Thanks in advance |
Depends.
What size rims does the Camry have and what size rim and tire are you trying to install? You need to be concerned about diameter, rim offset, tire size, bolt pattern, rim hole size. Bolt pattern and rim hole size may be the same but offset may not. Larger rims on Camry have lower profile tires which the other vehicles may not. The result of this is the rim might bolt up but there are tire/chassis fit issues. |
