Source for ABS codes for 4th Gen, 1997 Camry XLE 2.2L
Does anyone know the description of ABS code 62 for 4th Gen, 1997, Camry XLE 2.2 liter engine (or where I can find these codes)?
Thanks, KH |
Does the car have ABS?
Code appears as ABS malfunction. |
ABS Code #62 indicative of anything other than Bosch ECU?
Joey,
Yes, this 97 Camry has the Bosch ABS ECU on the ABS pump in the engine compartment. I thought the ABS code 62 was indicative of the two broken wires on the ECU circuit board, so I opened the ECU. However, visually, there were no "commonly spoken of" broken wires on the board. Is the code 62 indicative of anything else? I have also cleaned the electrical connection contacts, checked the fuses, and attempted to reset the ABS system. And possibly some other measures that I am not thinking of at the moment. I have fairly high-resolution photos of the circuit board if that would aid in my diagnosis. Sorry, for the delay in response, Kevin |
