struts/shocks 2000 camry
What does the 2000 camry have struts/shocks? Approx. how many miles did they last, and how much to replace?
Thanks |
RE: struts/shocks 2000 camry
i changed mine @ 80K w/KYB GR-2. A little below 400 shipped on eBAY for all 4. But they're suppose to last up to 100K.
in reality stock shocks are probably worn out by 75k miles , but its such a gradual reduction in performance that you really dont notice , until you put the new tokico,bilstein or kyb's in .
i think they are all about the same price . i just put on tokico's because they are slightly more forgiving on rough roads , but still have similar performance as the trd bilsteins that were on my 99 . |
How easy wwere they to replace?
ORIGINAL: james007 How easy wwere they to replace? the rear is a complete pita . you have to take every piece of trim out of the back to get to the upper mounting bolts . it took me longer removing the trim (breaking several little cheap clips in the process) than the springs ., but all in all its pretty straight forward . pick up a haynes repair manual from an auto store it may come in handy . |
i feel the car from the driver side low lettle abit from the passnger side from front
I have 2000 toyota camry 4 cyl
its 76,000 miles its excellant conditions recently i feel the driver side from the front wheel low rather than the passnger i went to check it if it need alighiment but then result "alighmnet is complince with manufacturing company"excellent is this from the shocks or springs?? |
