Tire size for 98 V6
215/60/15 is not as tall as a 205/65/15. I would really like to go with a 215/65/15 if I could find someone that has done that on a gen 4 Camry, and had no issues.
Diameter in inches of the wheel that the tire is designed to fit. There is the rare exception metric diameter tires, such as the use of the 390 size, which in this case would indicate a wheel of 390 mm in diameter. Few tires are made to this size presently.
The width is measured in millimeters, the diameter in inches. The second number is side wall height, which is a percentage of the width. For instance, 205/65/15. This tire is 205 millimeters wide (8.07 inches), the side wall height is 65% of the width, or 133.25 millimeters (5.25 inches) and the rim diameter is 15 inches.
Do have pictures of that setup?
