Vibration issue-'98 Camry LE
Hola!
98 camry LE 2.2. The car's had a vibration issue between 50-60 MPH. Recently got an alignment, balanced, and 4 brand new tires and the problem has not gone away. Could it be wheel bearings? Any thoughts would be appreciated, as I'm not sure where to start with this... |
Wheel bearings tend to make a growl or roar at lower speeds that blends into the road noise about 30 mph.
Is the vibration still present, worse, better when coasting, accelerating, etc? |
RE:
It seems to alleviate while accelerating, but the vibration doesn't go away. It's really bad from 50-53ish, and gets better until about 60 where it dissapears.
What happens when you slow down from 65 to 55?
Check the rims for damage or wobble. A bad inner CV joint can cause vibration. |
From 65 to 60, it's okay. Going all the way down and remaining at 55 will cause a vibration. I'll check those things-thanks.
And researching how to do a CV joint doesn't look to fun to attemt on your own. I have a friend who has a shop and we'll have to look at it there.
