Wheel Brand?
my name says it all. I own a gen 4 camry. I'm bout to go look for wheels and want to ask if any of you know the:
Back Spacing Bolt Circle Lug Style and Offset |
RE: Wheel Brand?
we have no backspacing, we run +50mm offset on the stock 6" wheel. (gen3 cams had a +38mm on 6" set which meant more dish =))
no idea about the bolt circle but the PCD is 5x114.3 Lugs are 12x1.5, standard wheels use 60degree conical heads. hub centerbore is 60.1 (or so)mm |
