wheel shakes at highway speeds
I have a 1994 Camry XLE. The wheel shakes badly at highway speeds. The tires are relatively new. I just had the tires inflated and balanced. I get the same shaking. Any suggestions? Thank you.
Check for a bent rim, out of round tire, tire having separated ply, bulging side wall, loose hub (wheel bearings), loose tie rod or suspension bushings, brake rotor warping.
Agreed, all of the above could cause your issue.
