wheel vibrating with 20 inch wheels? does anyone know why this may be?
I have a 2007 Camry SE and I just recently purchased rims and tires. I went with 20's as 19's looked to small.
However, i when I go 50 mph or more the wheel shakes pretty bad and I have no idea what to do? I absolutely love the wheels and would appreciate if anyone has any solutions to this? I purchased gianelle 20 inch 8 x 5. I see a lot of 2007 camry's with 20's so I am hoping this can be fixed. The care rides nice when I'm just doing city driving Thanks in advance for any help |
RE: wheel vibrating with 20 inch wheels? does anyone know why this may be?
as far as troubleshooting i would start with wheel balancing. a wheel weight could of fell off. if that dosnt fix it than next step would be to get an alignment. that should do the trick. if it still does it than u might be looking at more expensive repairs. good luck!!
you mit need some hud-centric rings...had the same problem with my gs400.
Thank you. I am going to try these and will let you know how it works.
Thanks again! |
Yes, try both. I have 20"s on my SE, and had to insist on getting the hubcentric rings (from past experience with 18"s on a Nissan). I have no vibration in my steering wheel.
Most defenitly hubcentric rings had the same problem on my 2007 camry le with 17" rims and falken tires
check here .. as the same problem faced by one of the members >>> https://www.camryforums.com/m_5555/tm.htm
all the best :) |
