Will 14 inch Corolla wheels fit a 2004 Camry currently with 15 inch wheels?
I have a 2004 I4 Camry with the factory steel 15 inch wheels. I have a couple of sets of 14 inch tires I would like to use up on my Camry. Once I use up the 14 inch tires I want to go back to the regular 15 inch wheels. Does Corolla and Camry of the last 15 years or so have the same bolt pattern? I know Corolla went 15 inch around 2003 and have recently gone to 16 inch. Ive seen 14 inch wheels on late 90s and early 2000 Corollas. Im wondering if the 14 inch Corolla wheels will fit the 2004 Camry with proper clearance? Or what options of 14 inch cheap rims are available to run on the 2004 Camry?
Ok. So I'm guessing there is not a lot of tech support on this forum since there is no response to my question above after a couple of weeks. Perhaps since these cars are so trouble free one doesnt have to worry about being a mechanic to own one. But back to my initial question I've since noticed only 4 lugs on the aforementioned Corollas that had 14 inch wheels and I'm concluding this is not the same bolt pattern as my 5 lug 15 inch Camry wheels. But what I also noticed is the newer Yaris wheels look as though they are 14 inch wheels and have 5 lugs and perhaps they may be a candidate to fit. But being a newer car it will be a while before these show up in the junkyards and even still the price of the wheels should remain high for years to come. So again anybody know if the Yaris have the same bolt pattern as Camry?
Due to the way this site is setup after a few days posts get buried and are not longer listed on the first screen that comes up.
2000 Corolla uses a 4-lug 100mm bolt pattern and 14 x 5.5 inch rim. In 2003 Corolla went to a 5-lug 100mm bolt pattern 15 x 6 inch rim. 2004 Camry uses a 5-lug 114.3 mm pattern. Thus the rims are not compatible with both cars. |
Thank you for you reply!! I've since noticed those Corollas rims I asked about were 4 lug wheels. But are the earlier 5 lug Camry 14 inch rims compatible or is the bolt pattern different? If so what years? Thanks very much!!! Sorry it took me so long to check back here. I must have opted out of email notifications when I got a reply.
(Post 81217)
Corolla eventually went to a 5-bolt rim but with a 100mm bolt pattern. Camry always had a 5-bolt rim but had 114.3mm spacing.
Camry and Corolla rims are not compatible for any year. If still wanting to go this route there might be a wheel adapter or lug conversion device, but no nothing about them. Search the internet on wheel adapters and lug conversion. |
