1991 camry will start then dies
I have this 1991 Toyota Camry Wagon 4 cyl w/ 190,000 miles. The problem; it now starts but then DIES right away. So we removed the injectors, cleaned and soaked them, re-installed but same thing. Replaced fuel filter but no luck. If I jump the cold start injector it will stay running (low Idle RPMs - as soon as I try to accelerate engine it wants to die). Also kept it running with carb cleaner through the main intake plenum with the air box disconnected. OBD1 = 43
Any help is so welcome!!!:confused: |
maybe its the engine itself... you might got an old engine.
