1994 idle problem
The car stumbles when in idle only. It does not die.
Other than that it drives great. I replaced the air and fuel filters, spark plugs and ignition wires, distributor cap and rotor, coolant sensor and cleaned the throttle body. I does not matter whether the air conditioner is on or if the car is in or out of gear. It is a 2.2 engine with auto trans. The car was made in Japan. The check engine light does not come on. Any sugestions. It only happens when the gas tank is 1/2 full or more Thanks Strafford |
you seem to replace the right parts... can't think of what causing it.
Originally Posted by full house
(Post 66407)
Strafford |
