Not the battery cause the lock and unlock buttons on the remote work fine. Yet pressing the trunk lid open button does nada. Could it be a fuse; if so which one?
andry
08-25-2008 06:08 AM
RE: 2003 Camry XLE trunk lid remote button issue
i'm sorry i dont understand. you mean you can't open the trunk use remote but button does nada, right? could you unlock the door use remote?
crazygravy
08-25-2008 06:13 AM
Right the remote buttons to lock and unlock the doors work fine it's just the button for the trunk that doex nothing
andry
08-26-2008 05:11 AM
it sound like you need reprogrammed the remote.
mothorton
03-19-2017 03:28 PM
You gotta hold the trunk unlock button down for at least one second for it to work....are you doing that? When I bought my used 2003 I thought my trunk release wasn't working, until I read the owner's manual a second time, CAREFULLY!
Rashied Djamin
03-07-2020 12:03 AM
Originally Posted by mothorton
(Post 95167)
2003 camry
Whoa!!! I feel like a complete idiot!
The light in my trunk wouldn't come on a little while after I bought it used. I think at the same time the button on fob stopped working. At least the lever next to the seat worked so I just limped along for almost 2 years.
Finally the latch itself broke so I had to replace the whole thing. THAT'S when I discovered the wires etc, behind the trunk liner. Turns out the plastic receiving end on the latch itself broke. Naturally when I installed the new latch, I plugged in the "male" part and the light came on! But, the fob still wasn't working. I figured that now it finally would. No success. That's when I read THIS! I ran outside, pushed the button and HELD it, for maybe a second and a half. Actually till it OPENED!!! WHO KNEW!? (Well you did) Thank you, thank you, thank you. I'm a delivery driver and use the trunk for deliveries. But I always had to put the deliveries down, unlock the drivers door, pull the lever, pick up the deliveries... Well you get the picture. Guess what!!!! Now, I can just push the button, and put my crap in the trunk in one smooth motion.
jules90f
12-10-2021 03:22 AM
The latch on my 2003 Camry's trunk also broke. By any chance, do you still have the part number? Need to get a replacement.
Thank you so much for the link. Now I can order the part!
Alpoi
05-18-2022 02:41 AM
there is a manual switch that is situated close to the storage compartment hook for a safty lockout it could have been exchanged coincidentally hope to make sure.hope this makes a difference.
