2010 camry 4cylinder stalling
So I was at a buddies house. We decided to go to Walmart, 2 blocks down, the car started shuddering. I pulled over and it was idling super rough. It does start but doesn't like to stay idling. My assumption is I have a piston that's not firing at all and another intermittently misfiring. I tried new spark plugs but that did nothing. I was told to try an ignition coil, but they're $100 and I don't want to spend money on it if that's not the issue. So my question is. Does this issue sound like an ignition coil went out? Or is there other issues i should check for?
The check light on?
How is the engine power, normal, rough? |
(Post 93704)
The check light on?
If the check light is on. The best and easiest way it to get the code(s) read. Depending what state you are in, many auto parts stores will read the code(s) for free.
There are codes for ign problems. Such as misfire on the X cylinder(s) numbers. Based on the cylinders numbers you can determine what ign coil it is. My guess is its a coil. If an intermediate problem the check light may go off when the engine is running OK. |
(Post 93709)
The engine was OK one moment, vibrating the next?
Get a second opinion. What were the code(s)? Does the engine ever operate normally now? |
(Post 93759)
It could be just a stuck valve that needs to be reworked or replaced.
Once the cylinder head is removed, the mechanic should be able to fully determine the problem and what repairs are needed. |
I agree Joey but may I add (not knowing newer motors) removing the valve cover might show whats wrong. If a valve is just stuck, not bent you might work it free with a carb cleaner like gumout, i've done this with hyd. lifters to free them up and followed with a quart of trans fluid in the oil for a couple hours drive to run like new then change oil. Could a broken spring do this also if the single spring?
I've mostly worked on corvair,vw, 4cyl porsche, lov air cooled cars. |
(Post 93843)
Originally Posted by g3bill
(Post 93847)
