2012 Camry engine turns, will not start
Our 4 cylinder Camry, with 75000 miles, will spin the engine but doesn't start. Any help is appreciated.
Check for ign spark when turning engine over.
Do you have another ign key? If so try it. |
(Post 99602)
Hi, seems like I’m having the same problem you had. After I disconnect the battery terminal and reconnect it everything works fine until the next episode. No codes or anything of that nature. Long shot but did you ever fix the car?
Originally Posted by nhantech
(Post 107493)
Thanks for replying. Unfortunately I’m not so lucky. More than like an ecm for me
