96 camry engine swap. 2.2 to 2.0
I need some help from someone plz. I have a 96 camry and it has a 2.2 in it, and I got a engine from the junkyard that can from japan (2.0). The guy said that it will work. Well I swapped all the sensor and everything that I needed to. Well I got it in the car and the rear motor mount will not mount to the block. It looks like you can maybe get to bolts to work but it looks as if the transaxle may not be align correctly if I do that. Any Ideas.
