Camry Forums - Toyota Camry Forum (https://www.camryforums.com/forum/)
-   TCF Help & Suggestion Center (https://www.camryforums.com/forum/tcf-help-suggestion-center-7/)
-   -   97 camry door wont open.. (https://www.camryforums.com/forum/tcf-help-suggestion-center-7/97-camry-door-wont-open-40317/)
POKAROKA 03-10-2012 07:59 AM
I own a '97 camry, the front passenger door suddenly will not open. The lock will not unlock completly,and unable to open from inside door or out. Can somebody help me please ?1
toyomoho 03-10-2012 11:08 AM
You tried both manual and electric interior locks?
If not most likely the electric door lock actuator is broken.
To gain access requires removing the door panel and the door be open.
If lucky an auto locksmith or body shop can use a tool to open the door. If the door can be opened remove the door panel before closing or don't close it until the problem is fixed.
The internet has lots of posts on replacing the actuator.
POKAROKA 03-10-2012 03:28 PM
'97 camry door problem...
Thanks toyomoho !! I'll keep you posted.
POKAROKA 03-11-2012 06:23 AM
Power Mirror
My power mirror used to tilt down in reverse,but not any more. Any suggestions ?
toyomoho 03-11-2012 09:19 AM
What?
full house 03-12-2012 10:09 PM
that's strange, how can you get out and in if doors won't open and close?
POKAROKA 03-13-2012 05:51 AM
Hence the problem !!! I've tried every way i could to open the door with no success !! Both inside and outside levers wont catch ,it wont unlock.
toyomoho 03-13-2012 09:57 AM
The power lock actuator may be bad.
To access requires removing the door panel, or perhaps a locksmith or body shop can use a tool open the door.
staurthill 09-12-2012 02:21 AM
Hi,.
Look for access holes with either round clear tape or black plugs covering them. Can't remember if your car has either. Otherwise, diligence and patience with a good steady hand.
locksmith boston
