camry 2002
Hi every ones!
can some one help me to find out or give me any suggestion please! My wife car camry 2002 has a problem last night all the light in side the instrusment panel odomedle needle, RMP needle, temperature needle and fuel gauge none of them work only the the gear light like Drive park revert L working, and I did check out the fuse boxes and none of them out (broken) but when I remove the one of them on very top left corner and put it back then I hear the sound din din .. and every thing work again but not for long and try again it work but not the third time on the day .. please help if any of you know about the problem, Thanks, |
Any of these lights work?
Glove box light. Light the illuminates the gear selection letter AT THE shifter arm (located between seats). Cig lighter light. Heater control lights. All above including instrument lights are powered by Panel fuse located behind instrument panel drivers side. The gear lights on the instrument panel are powered by a different circuit. |
maybe the bulb are not working anymore... it would be the bulb.
Thanks, my friend but that not a case because after I try to pull the fuse out and put it back every thing work again so that not the bulb, thank you anyway
thanks Toyomoho !
all the light work only instrusment panel not working any time I turn off and restart |
