MikeLikesCars |
08-07-2019 08:54 PM |
Leak in the ac
I have a 2007 camry with v6 and recently the ac started blowing hot air. I charged the system using a charging kit and the system worked great but for only about 2 weeks. Now is blows hot air again. I have to conclude that the system has a leak. I purchase another charging kit which has a UV additive and a UV light to detect the leak. Have seen the YOUTUBE vids on how to so that is not the issue. What is the problem is what to do about the leak. If it is a major component that requires replacing parts then I know this will be beyond my capability since I don't have the necessary equipment to drain and vacuum the system. So long story short - I would like a recommendation for a repair shop in the Greensboro NC area that forum members have used and would recommend to a fellow Camry owner. Thanks in advance for any feedback
