Need help identifying part.
This is connected next to right side cooling fan ( on a 2000 camry le 2.2 4cyl sedan), connected to a sensor (i think) in the radiator. Im thinking its for the coolant temperature sensor but maybe not because the sensor is higher up on the radiator hose instead of under the radiator. if someone could help me out and tell me what connects into here id really appreciated it https://cimg5.ibsrv.net/gimg/www.cam...09d81cd267.jpg
What are the colors of the wires?
2 wires, one white with a strip of black the other blue with a strip of white
The wire colors indicate the plug goes to the water temp sensor switch on radiator. The switch is on the lower radiator tank facing the engine.
