Toyota camry 4cyl 1999
Camry just quit running while sitting at stop light. Car will not restart it turns over but does not even try to crank. Car is getting fire an I give it a splash of either in are intake an still doesn't respond at all. Any ideas were to start.
How good is the spark? Should be able to gap 1/2 inch of air.
Remove the plugs and determine if fuel was getting to the cylinders. This car have an immobilizer, is there a blinking red light on on the dash? Did you check all the fuses? |
Wonder how this turned out. Timing belt?
