Toyota camry 4cyl 1999
Old 06-20-2015, 03:19 PM
scott baldwin's Avatar
Default Toyota camry 4cyl 1999
Camry just quit running while sitting at stop light. Car will not restart it turns over but does not even try to crank. Car is getting fire an I give it a splash of either in are intake an still doesn't respond at all. Any ideas were to start.
Old 06-21-2015, 10:01 AM
How good is the spark? Should be able to gap 1/2 inch of air.
Remove the plugs and determine if fuel was getting to the cylinders.
This car have an immobilizer, is there a blinking red light on on the dash?
Did you check all the fuses?
Old 07-10-2015, 02:49 PM
dbbd022's Avatar
Wonder how this turned out. Timing belt?
Beedo
10-09-2016 09:43 PM
Beedo
02-09-2013 04:53 PM
tobi
02-25-2007 10:33 PM
kirubel98
02-01-2006 11:46 PM
kirubel98
08-22-2005 05:38 PM
Quick Reply: Toyota camry 4cyl 1999
