2000 camry Check engine light P1130, P1135
Old 02-29-2008, 07:27 PM
kjcho92's Avatar
Default 2000 camry Check engine light P1130, P1135
Hi,
I have a Camry 2000 LE, with 70k miles on it. CEL came on, and I checked the codes at AutoZone.
They came out to be P1130, P1135. Air/Fuel Sensor Circuit Range/Performance, and Air/Fuel Sensor Heater Circuit Response.
So I took it to Meineke. I didn't know there is a $89 charge for computer diagnostics. It didn't take them that long. 40 minutes total, including an engine oil change and a tire rotation.
I felt like I was being ripped off.
And they gave me a quote for
1. VSV valve for $150
2. O2 sensor for $250
3. A/F ration sensor for $250
I couldn't understand, because I had VSV valve changed about a year ago, that controls the EGR valve. I told the guy, and he says there are three VSV valves, and the one that's out of order is the one with the Canister.
I wasn't sure whether I should believe this guy or not, so I just came home, just paying for the diagnosis.
I did some searching, but no one points to a VSV valve for the codes mentioned above.
Should I still believe these guys? or should I go to another shop, (I'll have to pay for diagnosis again..) and get a second opinion?
I had replaced the O2 sensor about 2 years ago as well.
Can anyone help me with this?
Thanks.
KJ
Old 03-03-2008, 12:03 AM
toyoboy's Avatar
Default RE: 2000 camry Check engine light P1130, P1135
go with your gut feeling and get another opinion, that shop sounds shadey
Old 03-05-2008, 12:32 PM
Camry05WS's Avatar
I would call around to some other shops. You can also buy a diagnostics reader at advance auto, NAPA, ect... Mine cost around 75.00 I think. But I would get a second opinion on the repair cost some places do not charge diagnostics if you have the repair done there.
Nathan
vin888
11-13-2019 06:19 PM
vrubinsky
05-30-2015 08:44 AM
Dhomsey
09-25-2013 09:35 AM
sconley
03-02-2012 09:33 AM
nj55
10-15-2009 07:16 AM
Quick Reply: 2000 camry Check engine light P1130, P1135
