Browse all: Interior Guides
- Toyota Camry 4th gen Why is Airbag Light On
Guide to diagnose trouble and recommended solutions
AIR BAG LIGHT!!! 97-01 Camry
98 Camry LE...
Ok I don't know if this is a know problem with this particular model year, but recently my 98 camry airbag light has been on and its weird because sometimes it will go off about 5 minutes or so and then sometimes it will blink and again it will come on regularly when I start up the car for a 3 seconds and then go off (normal) for that ofcourse, but other than that its strange. Is this a reminder light to get my airbag serviced for its 10 years? Now I have been messing with the instrument cluster here and there fixing blown out light bulbs and fixing the "D" shift indicator light for some reason that it keeps popping out don't know why exactly, but it has been replaced is what I'm saying with a new bulb. Anyway I thought it could be a short maybe from pulling it out too much, but I doubt it and I've checked all the wires and connections and they seem fine. Anyone has this problem with their camry with the airbag light?
RE: AIR BAG LIGHT!!! 97-01 Camry
yeah I know I tried putting black tape over it, but at night the red still glows behind it lol. I hate that this is happened. BMW's have problems with there air bag systems too. Every bmw I've seen had there airbag lights on.
sensors are shot. they are expensive (and why shouldnt they be?)
so basically your airbgas will not deploy upon a crash.
i forgot if there is an airbag fuse/relay that you can pull that may disable the light and the sensor completely. this would be good in case you do get into a crash and the airbag deploys sometime after impact, which would cause you more injury.
