Power Locks Click to Lock and Unlock by Themselves
Old 01-06-2012, 09:37 AM
dboy11's Avatar
Default Power Locks Click to Lock and Unlock by Themselves
I'm not sure what this is, but when I have the key in the on position and open and close the drivers door. The power locks click to the locked and then unlocked position. The actual **** doesn't move but it cycles on and off.
Any ideas?
Old 01-06-2012, 01:31 PM
Year of car? Does it have remote controlled locks?
Old 01-09-2012, 11:28 AM
dboy11's Avatar
96 Camry 4 banger and no manual locks no remote
Old 01-09-2012, 01:38 PM
What happens when you use the drivers door switch with the key on and door closed, does the **** on the inside of the door move?
If the ign key is on and door is open, if the lock switch is moved to lock, the lock will cycle closed then open.
If manual locks might be a short or other fault in the wiring. Typically this happens between the drivers door and chassis. With constant door usage the wires flex and can break.
Also check for a stuck or sticking door switch ,check all of the door switches.
Robert Wolf
09-09-2016 10:29 AM
Childeric
05-09-2015 12:02 AM
linsjean
04-06-2012 08:55 AM
meapollo
06-18-2011 10:24 AM
paradise_trio
03-13-2010 11:01 AM
Quick Reply: Power Locks Click to Lock and Unlock by Themselves
