Sponsored by:
Sponsored by:
94 Camry 2.2 4cyl won't start
Old 05-04-2011, 04:29 AM
keatsy's Avatar
Unhappy 94 Camry 2.2 4cyl won't start
G'day, 94 Camry 2.2 ... 217,ooo km .current overheating problem and about to ?fix with seal-up as there is bubbles in the radiator, However, the main problem I have is after I drained and refilled the radiator with water and started it only to have it conk-out a minute later.
This is my problem, now it won't start.
I have replaced the platinum plugs, rotor button, dissy cap and leads.
Good spark at Dissy, poor spark at plugs.
Rotor turning ok and aligned with compression stroke #1 Cylinder.
There is fuel in tank. Engine turning over but no start. even with 'aerostart' and squirting petrol into the throttle body.
Old plugs were equal in colour and grit
Please help..
Keatsy
Old 05-04-2011, 10:00 AM
Can you provide more details of the overheating issues? Are you sure it is not a blown head gasket, seal up will most likely not fix this problem.
How did the engine run for that one-minute it did run?
How about the spark plug wires?
npn74
03-24-2020 02:38 PM
JCProV
02-03-2012 08:19 PM
Iflyrc
09-06-2009 09:23 AM
fred
03-15-2009 07:07 PM
Quick Reply: 94 Camry 2.2 4cyl won't start
