Sponsored by:
Sponsored by:
Need opinions, I'm totally frustrated.(Long)
Old 02-10-2016, 08:25 AM
C908's Avatar
Default Need opinions, I'm totally frustrated.(Long)
I have a 95 Camry 131,000 miles my father purchased new and was given to me when he passed away in 2014. The car has always been maintained and never a problem until several weeks ago. It became hard to start and wouldn't idle. I changed the plugs,fuel filter, cleaned throttle body, cleaned air sensor and made sure the air cleaner was clean. The car was better better but still not right so I took it to the local Toyota dealer. They first told me I needed an air idle control valve so it was replaced. That improved the idle but the car was still not right. Next thing discovered was a hairline crack in the distributor cap. They replaced the cap including rotor. Car still not right so they checked the plug wires but said they were ok. They decided the injectors were carboned up so they cleaned them and said I was good to go. I forgot to mention I was due for a timing belt so I had it replaced. They had my car for 8 days and my bill was $867.00 after using a $100.00 discount coupon. Everything seemed fine until the next morning when I couldn't get my car to start. It would turn over but just wouldn't fire. After many tries it finally started and seemed to run fine. I went to the dealer and they said it has to be dirty injectors causing the starting problem. I was told if the injectors don't come clean they will need to be replaced at about $300.00 a piece. I went and bought two bottles of Cevron Techtron put it in the tank and drove 200 miles on the highway over the next two days. I thought the car was better but it has gotten colder the last few nights which seems to have an effect on the car starting in the morning. It won't start this morning, cranks but won't fire (19 degrees) and it took about an hour yesterday to start it. After running the techtron through the tank I'm now trying Seafoam, drove 150 highway miles. I'm thinking I may have to try and change the injectors myself. I watched a you tube video and it didn't look bad if you can just get the fuel rail off. Looks like it is in a tight place that might be hard to access. I would appreciate some thoughts and opinions, thanks.
Old 02-10-2016, 11:58 AM
What engine V6 or 4-cylinder?
Any chance of having bad gas in the tank?
When the engine doesn't start, have you checked for ign spark?
Are the starting problems only occurring when the engine is cold?
Are the only problems hard starting and idle? Once the car starts does it drive normally, no missing, good power, etc engine hot or cold?
Old 02-10-2016, 05:44 PM
C908's Avatar
My car has the 2200 4cyl engine. The Toyota dealer has supposedly checked everything that could possibly be causing the problem. They are adamant the problem is the injectors but I don't know what to believe at this point. I'm waiting to see if cold temperature has anything to do with hard starting. It took me about 45 minutes this morning to get it started and an hour yesterday morning. The temps were in the high teens both mornings. Once I get it started it runs and starts fine for the rest of the day.
Old 02-10-2016, 08:48 PM
Is this car California or federal emissions certified? There is a sticker under the hood stating FED or CAL or such.
Seems odd once started the engine runs OK as clogged injectors stay clogged. Clogged injectors can also cause lack of power and missing.
If you remove the injectors there are businesses that will clean and flow test them for around $25/each. Removing the injectors is not too hard. Suggest removing the valve cover to access them. You will need an injector seal kit for each injector when reinstalling them.
Did the dealer check out the coolant temp sensor for the computer? This tells the computer what temp the coolant is to adjust fuel, timing, etc. If bad it can cause a number of problems.
Old 02-10-2016, 09:31 PM
dirty hands's Avatar
5S–FE engine there
i didnt see anything about fuel pump pressures at the injector rail at cold start
this attachment is and exploded view the injectors
if you want to go DIY or more details . its available
File Type: pdf
Old 02-10-2016, 10:30 PM
C908's Avatar
Thank you for your response, this is not a California car. I have been doing research and it sounds like the coolant temperature sensor unit could be the problem. I have a hard time believing the injectors are the problem as the dealer keeps telling me. They used injection cleaner and bypassed the fuel system. When I got the car out of the shop I ran two cans of Chevron Tectron injection cleaner on the highway. After that I decided to run Seafoam and I'm on the second can of that. After 400 miles of highway driving with all that cleaner those injectors should be clean. I have replaced the plugs, fuel filter, cleaned throttlebody and air sensor. The dealer has replaced air idle control valve, distributor cap and rotor, checked plug wires said ok and cleaned injectors. I also had the timing belt changed just because it was time. I need to see how much the coolant temp sensor is and maybe change that myself. I've thrown a lot of money at this old car but it was purchased new by my father who passed away in 2014. The car is in really good shape and I hope to keep it for many years, just turned 131,000 miles. The only time I have the starting problem is in the morning after it sits outside all night. I would like to hear your thoughts, thanks, Chuck
Old 02-11-2016, 12:20 AM
i owned a 95 4 cyl auto for a long time and didnt have this problem
parked outside in all sorts of weather
the list of parts and checks you added covers all i would have done to solve a no start problem
is the battery holding up to lots of cranking
if its a manual i am totally stumped
that camry has a starter relay . worth a try ...maybe swap that for another
Old 02-11-2016, 11:39 AM
C908's Avatar
After doing a great deal of research last night someone suggested pumping the gas pedal twice before turning the key. To my surprise it worked and my car started right up. Another thing I have decided to do is change out the engine coolant temperature sensor. I will be doing that this afternoon and then tomorrow morning I will try and start the car without pumping the gas twice. If it starts I would say that sensor was my problem. If it doesn't start then I will go back to the two pump before turning the key. I will respond back with my results so it can possibly help someone else with the same problem. I really love the forums they are such a big help. Thanks again.
Old 02-12-2016, 11:19 AM
C908's Avatar
Changed the coolant temperature sensor yesterday, went out this morning and it fired right up. I really hope this fixed my problem and if it keeps starting every morning then I would say it's fixed. The dealer never mentioned it, I guess since it's a $25.00 part they were not interested. They were sure interested in trying to get me to replace the injectors for $1200.00.
Old 02-12-2016, 02:58 PM
Great!
Post back with an update.
Quick Reply: Need opinions, I'm totally frustrated.(Long)
