Sponsored by:
Sponsored by:
Oxygen Sensor Replacement Interval?
Old 02-28-2008, 12:02 PM
pedro's Avatar
Default Oxygen Sensor Replacement Interval?
This question is probably for toyomoho or another tech but I'll take input from anyone.
toyomoho posted on another thread that the A/F sensor tends to get lazy with use and suggested it be changed when the poster complained about poor gas mileage.
My5FSE has 2 oxy sensors. One is the main (single wire) andthe otherafter
the CAT is the Sub Oxy Sensor (2 wire). I don't consider either of these to be an
A/F sensor as I think that would require a sensor with a wider range and maybemore signal wires.
I assume the main is non heated and the sub is heated (second wire). I bought this car used with no known service history andnow with close to 149K so is it advisable to replace either or both of these sensors as a normal maintenence procedure?
There are no drivability issues and an inspection of the plugs a short time ago showed no rich burn condition. I never have calculated the gas mileage because I usually never fill to top on any one gas up.
Advancesells the main (single wire) generic Bosch with no wire connector for about $35 and with connector for about $110. Dealer wants about $140 for the main and over $200 for the sub.
Old 03-02-2008, 11:55 PM
toyoboy's Avatar
Default RE: Oxygen Sensor Replacement Interval?
i will suggest 120k for my customers ,but if you're a tech. should be be able to test how activethe o2 sensor is and determind if you want to replace it.
Old 03-03-2008, 06:00 AM
pedro's Avatar
The test seems to be just a voltage reading, but will that show the reaction speed, or does that matter?
bigblue
07-05-2012 11:44 AM
modelbehave
05-19-2010 05:57 PM
JPCAMRY
06-17-2008 01:55 PM
dimon81
09-25-2007 11:01 AM
ntxgb
05-29-2007 04:23 PM
Quick Reply: Oxygen Sensor Replacement Interval?
