Sponsored by:
Sponsored by:
Should I change the transmission fluid?
Old 02-21-2017, 08:54 PM
mobile1's Avatar
Question Should I change the transmission fluid?
I have a 1998 Toyota Camry with 127,000 miles on it.
Old 02-21-2017, 10:09 PM
Is this an automatic?
If so, my opinion is to change the fluid at at least every 50K miles. Change it all not just in the trans pan.
Don't do flush with chemicals. Use a procedure or machine that does not use external force to move the fluid out. But uses the trans own fluid pump to do this.
If a 4-cylinder engine. The auto trans differential also has its own fluid compartment that needs changing.
Old 02-22-2017, 08:34 AM
mobile1's Avatar
Smile
Thank you.
greyghost
08-11-2011 04:14 PM
evanjah
12-27-2010 04:50 PM
hughfree
02-05-2010 10:28 PM
melahi
06-20-2008 09:49 AM
Quick Reply: Should I change the transmission fluid?
