Sponsored by:
Sponsored by:
What are the signs of a blown head gasket vs a cracked head?
Old 11-21-2008, 02:26 AM
Player's Avatar
Default What are the signs of a blown head gasket vs a cracked head?
I have a friend with a '95 Camry that is getting oil in the coolant. Any way to tell what exactly the problem is without tearing it apart?
Old 11-21-2008, 08:21 AM
pedro's Avatar
Default RE: What are the signs of a blown head gasket vs a cracked head?
Doesn't make any difference, both require you to remove the head to fix. Once the head is off you can have it crack tested before deciding what solution will work.
Old 11-21-2008, 10:43 AM
Player's Avatar
The problem is that they don't want to deal with it if it's the head, but they'll do it if it's a head gasket. Just trying to figure out if there is any way to determine that without ripping it apart. Are there some symptoms that are more common for one than the other.
Old 11-21-2008, 11:59 AM
Player's Avatar
Anyone know if either head gasket problems or cracked heads are at all common on a '95, 4 cylinder engine?
Old 11-21-2008, 12:37 PM
pedro's Avatar
Did the car overheat before this happened? There is no way to tell either HG or head from the outside. What if I told you that 80% of the time it's HG, you would still not be able to determine if you were in the 80% or 20% group. Once the head is off you can see the HG break without spending on crack inspection. If you decide to fix it is worth getting the crack inspection as a safety precaution. But if you see no HG break the head could still be warped so that inspection is usually done with the crack inspection. Clearwater Heads offers an exchange program which might be a better way to go.
Old 11-21-2008, 01:25 PM
Player's Avatar
That's a good thought, thanks for the link!
Old 05-04-2010, 06:27 AM
george.mikal's Avatar
hmm.ok
i will give my views later
mag176
05-05-2021 06:15 PM
briandownunda
10-19-2015 06:07 AM
mbas
07-01-2008 06:02 AM
withquestion
02-22-2007 12:24 PM
Al Hanks
05-31-2006 01:55 AM
Quick Reply: What are the signs of a blown head gasket vs a cracked head?
