Camry Will Not Stop Beeping While Car is Off
Old 10-20-2016, 09:11 PM
vandexa4@gmail.com's Avatar
Default Camry Will Not Stop Beeping While Car is Off
Hello everybody.
I have a 2012 Camry SE V6 with keyless entry and car is making a beeping sound about every minute.
- The beep is similar to the tone of unlocking your car with the car keys, but this beep lasts for about a solid 3 second while the beep from unlocking your car is about 1/2 second.
- There are no warning signs on the dashboard to indicate any problems
- I reopened and closed all doors, windows, and trunk. Problems still persists
- I set off then stopped the alarm using the key, did not solve the problem
- I tried disconnecting the battery and the car is still beeping with the battery disconnected
Anybody have any suggestions on what else I should try?
Thanks in advance.
Old 10-21-2016, 10:04 PM
If the battery is disconnected and 90 seconds passes, the car should be no longer powered.
Have you checked for non-Toyota items such as a garage door remote or after market installed battery powered item whose battery is now running low?
aahmes57
11-03-2012 07:30 PM
rakeshcamry96forum
02-25-2010 01:32 PM
onu2002
11-18-2006 11:24 PM
Quick Reply: Camry Will Not Stop Beeping While Car is Off
